Use this procedure to display MLD snooping interface parameters.
  1. Enter Privileged EXEC mode:
    enable
  2. Display MLD interface information:
    show ipv6 mld interface [gigabitethernet {slot/port[/sub-port]}] [vlan <1-4059>]
Switch:1>show ipv6 mld interface
                         Mld Interface - GlobalRouter
IF   STATUS VERS  OPER VERS QUERIER                                 Wrong Query JOINS MODE
P1/3 inact  2     2         2001:0db8:3c4d:0015:0000:0000:1a2f:1aaa   0      		0     pim
V666 inact  2     2         2001:0db8:3c4d:0015:0000:0000:1a2f:1bbb   0 	     	0     pim
Switch:1>show ipv6 mld interface vlan 10
                                  Vlan IPv6 Mld
VLAN QUERY QUERY ROBUST VERSION LAST  SNOOP  SSM     DYNAMIC
ID   INTVL MAX                  LIST  ENABLE SNOOP   DOWNGRADE
           RESP                 QUERY        ENABLE
10   125   10    2      1       1     false  false   enabled
Switch:1>show ipv6 mld interface gigabitethernet 1/11
                                 Port IPv6 MLD
PORT QUERY QUERY ROBUST VERSION LAST  DYNAMIC
NUM  INTVL MAX                  LIST  DOWNGRADE
           RESP                 QUERY
1/11 125   10    2      1       1     enabled
1 out of 1 entries displayed
The following table describes the variables for the show ipv6 mld interface command.
Variable Value
vlan <1-4059>
Displays MLD snooping information for the configured VLANs.
gigabitEthernet {slot/port[/sub-port]}
Displays MLD snooping information on a specific interface.
